Quick question 1G TB
jaredo
Feb 26, 2005
Fort Myers, Florida
I just picked up a 1G TB for my 2g. What I noticed on this one is that it has about 1-2" of built in pipe where the 2G elbow would normally mate up. Do I have the wrong 1G TB year? It has all the same vacuum/hose connections, and TPS. Just the 2" of pipe before would be a bit difficult to cut off.
nope, that's the appropriate year TB, just that its NONTURBO. I'm on the same boat as you and have decided to just suck it up and buy a 1g turbo TB.
if you really want to use it, you'll have to custom fab [ or do something ] to make it fit to the UICP. i.e., use a silicon coupler.
If I buy longer bolts and make a custom elbow/piping, other then that it would work the same?
thats the main reason why the nonturbo TB is nondesirable [ gee, guess how i found out too :rolleyes: ]. you have to custom fab a way to connect your pipes with the outlet "lip".
p.s., you need shorter bolts ;) maybe 60mm
edit* yes, it will work the same as a turbo TB
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
