Quick 1g question
The 1g Eclipse GS came with either a 1.8 SOHC engine (4g37) or a naturally aspirated 2.0 DOHC engine (4g63). The two are very easy to distinguish when looking at the valve cover. If your spark plug wires sit in a "valley" then it's DOHC. If they sit nearly flush it's a 1.8 SOHC engine.
No you cannot swap a 4g63 into a 420 2g car. It is not a drop in motor. It would be expensive and require a very large amount of fabrication. The same as if you decided to bolt a 4g63 into a toyota or something. The chassis is completely setup different in a 2g NT and this has been covered 1000 times before.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
