Quick Boost Gauge Question..
Albrecht09
82
Mar 14, 2012
Beaver, Pennsylvania
I have a Greddy boost gauge, and it works fine and all, but when I turn the car off the needle moves to the maxed out position (slightly past 2.0 kg/cm). It stays there even after I turn the car on, and will not start moving until I hit boost pretty decently hard. (~8 PSI will normally get it to start). It then jumps to whatever boost I'm at, and once I let off the throttle it starts to read normal. Is this normal for Greddy gauges? I have the vac line T'ed into the line that goes to the one fuel pressure solenoid I believe.
Pretty sure it isn't, I checked the whole thing. It reads fine after I hit boost the first time though, thats the strange thing..
This is the gauge that I have:
Its not going to the FPR line, but the solenoid that leads to the FPR on the firewall. Heres a pic.
