Kapok6
- 1,395
- 276
- Aug 10, 2004
Fort Worth,
Texas
Lettuce discuss an external fuel pump install on a 1G AWD. I have a few questions I am looking at a magnafuel MP 4301.
1.) I was going to use the stock hanger assembly, but just put an 8an bulkhead fitting in it and some kind of pickup tube with a sock. Does anyone with EXPERIENCE have a suggestion on what kind of tube to use as the pickup tube? I.E. SS, Aluminum, etc? Any advice on a filter/sock for the end of the pickup tube? I figure the measurement par should be easy. Just make sure the tube ends where the stock pump inlet would end.
2.) Mounting location. Being that it's external, I am guessing I can mount it anywhere. Is there a preferred location? My engine bay is kind of crammed, so I was thinking of putting it under the car near the back; maybe trying to mount it somewhere around where the rear seats are located and the body kind of slopes up. That would leave me those grommets right there to route the current power line(s).
3.) Would running the feed line off the drain plug be a better idea? Or just leave the drain plug alone and work on running it as mentioned above?
@bastarddsm @biglady112 @donniekak
. Mines been in my car since 2012, and working great. Proven for 140mph traps with 2 walbro 255's, and it was rich as f*** too.
