Questions about swapping a 6 bolt into a 94 GSX with a 7 bolt
hooter_rocks
Jun 26, 2005
Beverly Hills, California
I currently have a 7 bolt 2.0 turbo engine in my 94 eclipse gsx. I would like to purchase a used 6 bolt engine.
Can someone please link some reputable companies for buying said engine? This seems to be the most difficult part, and I'm afraid I will get screwed with a terrible engine. If you've had a good experience buying the same engine from a company I'd appreciate you sharing it.
Does the 6 bolt drop right in or will I need to make modifications?
I have an Evo 3 exaust manifold and turbo on there now, will that work with a 6 bolt?
Is this a difficult task that I should let a mechanic do, or would I be able to do this with a couple of friends?
Does anyone have any advice about the swap?
Why are you looking for a 6 bolt engine? Has your 7 bolt crankwalked?
www.karking.com sells engines and it is a reputable company.
No the 6 bolt does NOT drop right in.
Parts List
Compiled by Sean Caron with the help of the DSM1Gina2G list.
1G CAS (91-92 Optical Effect, 93-94 Hall Effect)
1G Oil Cooler (90-92 MD 157670 6bolt water cooled oil cooler)
1G Water Pump
1G Oil Pump/Front Case
1G Timing Belt necessities
2G Engine mount (modified) use 2G engine mount trimmed, with 1G tensioner arm
1G Timing Belt Covers (modified)
1G 90-92 6-bolt block (with whatever internals)
1G 6-bolt Flywheel
2G Starter Mounting bracket
1G Water Pipe
1G lower radiator hose
1G Thermostat housing/ Water Neck
1G 6-bolt oil pan Balance shafts (remove them or keep em, its up to you, we take them out)
2G Alternator
2G Power Steering Pump
2G A/C 2G Belts
On a 95-96 car with stock 2G head
Swap Plugs 1 and 4 with 2 and 3 (order is not important)
On a 97+ car with stock 2G head
No plug swap or injector swap is necessary
For a complete 1G 6-bolt head/block
Swap 2G ISC with 1G Throttle body 1G Coil pack and bracket
1G Head with internals
1G Intake manifold with stock 2G knock sensor
Reuse 2G sensor including oil, water temp, etc.
2G fuel rail to accommodate 2G Fuel Pressure Regulator
2G MAP sensor either in Intake Mani or T-d off of Brake booster Vac line
Relocate power transistor mount
Check it out, they have instructions on it too... http://www.magnusmotorsports.com/article_1g2g.htm
Yes the Evo 3 manifold and turbo will work on the 6 bolt.
Now, look at all the links I gave you and figure out if you can do the swap yourself. :thumb:
Parts List
1G Water Pump
1G 6-bolt Flywheel
1G Water Pipe
2G Alternator
2G A/C 2G Belts
94 is a 1G.....
shouldn't be too hard, since 1G's came with both 6 and 7-bolts depending on the year. i'm guessing it should be a direct swap.
My bad, I didn't pay attention to the 94 eclipse GSX. I figured you were talking about a 2G :coy:
1G 7bolt uses:
6bolt Head
6bolt Waterpump
7bolt Oil pump
7bolt Oil pan
7bolt Crank
7bolt Rods
7bolt Pistons 7.8:1 compression
It is a direct swap. :thumb:
    • george bromwell
    • pma1123
    • Sdcryan1
