Swapping a 90 FWD 6 bolt engine into a 92 AWD 6 bolt body.
imptuner
69
Nov 7, 2004
shrewsbury, New Jersey
Are the motor mounts the same.Like not the poly insert i know that is the same. Are any mounts longer or shorter. I have had a lot of trouble getting all the motor mounts in at once. now I got them all in but the trans mount. Its off by about 1/4, I have tried using pry bars to get it to go. I tried loosening them all so i could get them all in then tight in it up. It just wont go i really think something is wrong. Also all the Half's of the mount's that bolt to the car are from a AWD . all the Half's on the engine are FWD. Help me out please. :cry:
I dont belive the motor mount change in fwd the only one that i would think that would make a diffrence is the rear one. My only suggestion that I could thin of is line up the trans one first and adjust from there. it is in a tight position where the mount is located.
Irrational said:
There is this crazy thing called a search button. Use it noob.
BEFORE YOU REPLY:
1. No "Use the Search" replies - answer the question, link to the answer, or don't reply.
Read the rules asshole.
As far as I know the motor mounts are the same; FWD or AWD
imptuner said:
thanks for the help jerkoff but i already spent hours searching
Well i just don't think you should be doing swaps if you have to ask this shit. By golly i think your a noob.Probly had a Honda at one point and dumped a shit load of money into it now you want in on the big leagues . You cant handle it son. ;) :p
