question about clutch install on a 2g w/6 bolt block
empie1
1,063
5
Dec 30, 2004
albany, New York
I have a 6 bolt block with a 7 bolt head. I was reading that i need a longer slave cylinder rod on a 2g and i also read something about welding the pedel in a 1g. My question is, since my egine is both, wich of these do i need to do? Could some one please elaborat a little on the welding thing? I didnt really understand that part! Thanks!
You don't need to do anything. Install a washer behind the clutch pivot ball. 2G's don't suffer from the pedal issue like 1G's do. MAKE SURE THE STEP HEIGHT IS CORRECT ON THE FLYWHEEL. It will save you hours of bullshit and swearing.
