Ludachris
Founder & Zookeeper
- 8,887
- 4,742
- Nov 12, 2001
Newcastle,
California
I hopefully won't be running them for too long. Just until I get my Racing Harts sold and get new wheels that will fit. I'll be using 1/4" spacers. I know they sell them at Pep Boys, but I'd rather get some better quality ones if they're available since I'll probably run a couple track days with them. However, I need them in a few days.
The abs system is too outdated and its function (diagonal 2 channel) was annoying to me anyway. Now, about that light...
It helps to drill a couple small holes through the flange that mates to the hub, also, the flange has 5 spot faces to clear the stud flanges, try to chisel directly over the spot face as its thinner there. Use a good sharp chisel, the wheel is cast iron I think, so it takes a while, but once you split it you can pry the thing and it will break in two.
