putting AC Compressor back on
sharky559
191
Mar 6, 2010
Sanger, California
Okay so after one year of no AC . im putting it back on, so i need help on what part should i replace and how to refill the ac compressor with pag oil and how much:confused:
If the system has been open for a while I would suggest replacing the expansion valve(about $20 usually) and you always want to change the drier when the system is opened as the desiccant material can become saturated pretty easily. You can also unhook the line ends and blow through the lines with compressed air to ensure there is no trash in there. If you capped the lines after removing the compressor i wouldn't worry about it. Rent a vacuum pump and manifold gauge set from the local autoparts store to ensure your pulling proper vacuum on both sides of the system. Also you can buy can of r134 with PAG oil already mixed in it. Here's a link to a 2 part video system of how to do it properly without a $10,000 auto machine. [ame=http://www.youtube.com/watch?v=WblfmWnFPEc]Part 1. How to properly charge an auto AC R134a refrigerant air conditioning system. - YouTube[/ame][ame]http://www.youtube.com/watch?v=iNsyiFRfueM[/ame]
I just bought a '96 Tsi with the A/C removed and I want to put it back in. I know people remove the A/C due to overheating or lack of room, my car is coming next week so I have to take a look at the setup, but I can't go without AC!
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
