Punishment Radiator
but
190
Apr 7, 2009
Ridgecrest, California
I have the Punishment radiator Kit that came with slim fans and Fan shroud. I was wondering if anyone had suggestions if I should hard wire both fans into the stock harness,wire one fan into the stock harness,and wire the second fan from a switch and relay. Or should i use one fan and wire it to the sock harness or switch and eliminate the shroud alltogether? I would really like to make use of the shroud and both fans. I have also elimated the AC. Also,is it possible to hard wire both fans into ONE stock harness so both fans come on at the same time with out overloading?
Any suggestions help :thumb:
