RipperXX
- 5,788
- 172
- Feb 23, 2003
Royston,
Georgia
Originally posted by TSi95AWD
PTE GT3251 vs AGP T28You must be logged in to view this image or video.[/B]
Can I have your old turbo???
Originally posted by MNGSX
quote:
Originally posted by Ben K
PTE rates these in their small bolt-on housings as:
GT32 - 52lb/min
GT35 - 60lb/min
GT37 - 75lb/min
I just can't find anything on PTE's site with those ratings. Are those from PTE or from a PTE reseller stretching the truth?
I see the up to xxxhp ratings on everything but no lbs/min rating.
Originally posted by prostreetdsmx1
... Now i know the GT3255 is one that they custom make with the 52 trim wheel that is 76/55. so that number they can be diff on.
but aside from that they and i follow the standard garrett catalog.
Marti![]()
Ben. when i first ordered my batch of these i was told 42 lbs. as well. I mean they use the Garret setup, with out any real custom work except for the turbine housing so i might be missing something. Now i know the GT3255 is one that they custom make with the 52 trim wheel that is 76/55. so that number they can be diff on.
Marti![]()
Sorry ben i dont undertand the question or comment.How can you say you follow the catalog? I posted the ratings in the catalog, and the ratings that PTE and you like to use.
Originally posted by DCJ98GST
Why are these turbos not displayed on anybody's site? I just looked at "The Speed Factor" site and not one mention of them.![]()
Maybe we should all email PTE to start saying what wheels are in their turbos on the site to end this confusion.
They show this list:
http://www.precisionte.com/sportcompact.php
But it is still confusing which wheels are in which turbo because of the many combonations.
The reason I ask is because there were never two different housings for the Mitsu T3T4. PTE claims that you have the ability to choose between the .48 and .63 housings, however there was always only one housing.
If you ordered a .48, you received the Mitsu housing. If you ordered a .63, you received the Mitsu housing. There's only one.
I know the new GT housing is a little different, I was just curious if PTE was going to try and pull the same thing with the A/R ratios; have one housing, but call it a .48 or .63 depending on what the customer wants.
Next time you get a .48 and a .63 side by side in the GT housing, I'd like to see pics of the nozzle area and scroll area to see the difference between these two separate castings.
Ben
I see, Thanks for the clarification.
We are going to put this GSX back on the Dyno with a Better fmic and ARP head studs. With those installed we will push the car a little more and see what we can really get the GT3251 to make. I'll keep you updated as to when we do that and when the GT3255 goes on the Dyno.
Martin![]()
Are you dyno testing your shop car?
If you are, it would be nice to do back to back testing with the GT3251 to the GT3255 with the same mods on the same car. For comparisons sake.
I am sure your website would get a lot of hits if you were to post a good comparison like that up.
Originally posted by DSM90AWD
..and throw on a SCM-50 as your "control"
BTW.. Jim at PTE quoted me 500HP for the -51 and 550 for the -55
Originally posted by jdmawd
Take it easy little guy.If you were more specific with your initial post im sure you would have gotten more accurate responses. Maybe you should read your own posts, and see exactly what was said. Im sorry if my comments and pictures are offensive to you. Good luck with your future PTE purchase.
now that power alone is nice, however we have a lot of room to play with. That one was on a:
stock 7 bolt
HKS cams 64/72
DSMlink
93 octane
very consevative tuning
no timing adjustment
2 counts of knock
20psi
This one was the GT3251 with the 52trim (51mm/71mm wheel). The pulls were made on a AWD dyno.
Marti
TSF![]()
