Prothane Mount Problem
1gdsmnubie
Sep 4, 2007
bloomingdale, Ohio
I have searched and searched and found no one that has had this problem. I have 3 mounts that completely SHOT i bought a prothane kit from SBR i can only get 1 insert to go in and only 1/2 inch for the other side to go it, i went back to the site to make sure i ordered the right ones and the part #'s match but the price doesn't, and it looks like someone already tried to install these ### one is all cut up. Has anyone else had this problem?
You need to contact slowboy about sending you used items.
Contact this guy:
Jeff B
Sales Manager
Phone: 724-349-8417 x16
Email: [email protected]
AIM: jeffb006
Slowboy Racing :: DSM :: Engine :: Motor Mounts :: Prothane :: Prothane 1G DSM 4G63 Motor Mounts
the ones i apparently need?
Slowboy Racing :: DSM :: Suspension :: Urethane Bushings :: Prothane :: All 4 Engine Mount Inserts
the ones i bought, and yes those were the ones taht came up when i ordered them, i didn't see the other ones.
can someone ### tell me what the differnce is in the 2 because i dont see one other than the price!
they have the wrong part number in there for the 1G, the 13-1902 is the 2g kit, you need the 13-1901
also if your kit is the one in the pics it is wrong
Yes the new kit comes with a solid front roller mount. The old one was just an insert that went into the factory rubber mount.
I noticed in the new kits pro-thane is selling the front lower mount on a 1g, is a complete mount. no longer an insert. at least the last kit I ordered came like that. anyone else confirm that?
I bought the entire kit from ExtremePSI just last week and I got a complete front mount as well, no insert. It's not two piece either, just one piece so it'll have to be pressed in I believe.
I had to press mine in. Not too bad. Put it in a vice.. took me a try or two to get it lined up straight, but it went in on the 2nd or 3rd try. Pretty straight forward. Also, that mount that he has in the OP picture looks to be one of the half-mounts that should have another piece and a metallic insert that goes into the middle.
