1G prothane motor mount inserts bad vibration
redfield102j
170
7
May 12, 2015
Spring Creek, Pennsylvania
So i bought and installed a set of prothane inserts for my 91 talon tsi awd 5 speed. My issue is when the car is anywhere over 1200rpm it vibrates the whole car. At idle around 700rpm there seems to be next to no vibration. I am at a lose as to why... has anyone had these issues? Is it normal or should i be worried about something worse being wrong? Any help would be greatly appreciated
Yup that's what happens when you switch from soft rubber to hard urethane mounts. All the vibrations get transferred through the car instead of absorbed by the mounts.
My vibrations are much worse at idle than at any other point in the sweep. Double check to make sure your roll stop inserts aren't bound or sitting wrong. Its pretty normal to get your ass vibrating with poly mounts, but they should almost all but disappear after stepping on the go-go pedal.
The vibrations lessin when stepping on the pedal. And pretty much dissapear at idle. Its the lighter foot driving that is weird and constant speed cruising on highway at 60mph. It kinda feels like driving a truck with a tire rubing. Its weird.
Sounds normal to me. There are specific engine RPMs that are going to reverberate the block more then others and transfer to the frame but I wouldn't be alarmed. I have gotten very use to Poly inserts with Balance shafts removed and that is a whole other sort of vibration but still only on a small interval low in the RPM range where you don't ever sit.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
