92AWDHX40
Supporting Member
- 14,519
- 2,745
- May 22, 2007
Kalamazoo,
Michigan
Nice I know there is a lot of wire protection out there where did you get yours from.
I might do a more clean writeup in the future when time permits have a happy cyber Monday fellow tuners.
AWD
] the small insert [13-506] is for the rear mount, and the other three are for everything else, I think I'll have to modify one via trimming it down to get it to work, but that's about it.
.Wow great thread, the progress has been great! You are very lucky with those 2 finds. I've been trying to get my hands in one of those or even the mirage coupe, but here in CT is nearly impossible. I had to settle with a 2g spyder. Good luck with your build and project.
I still installed the camber plates just to see if they would help with the next problem... [hint: they didn't]
] but I'm working on procuring another shorter set that are still thicker then the stock ones which are not really weak per say, but I figure, if I'm doing this anyway why not try to find something stronger then stock units.
might work.
a little more testing.
