Project car help
gs-tboi12
Jan 28, 2008
oakland gardens, New York
hey wassup guys.
i made a list a while ago, it was pretty solid but then it got me thinkin if i should do any engine work. so i dont take a chance of busting my engine im gonna rebuild it, this is my entire list (top to bottom everything im gonna do to it).
help with the list if it needs anything would be great.
keep in mind money isnt a issue(but then again i dont have enough money to make it 600hp)
theres no exterior mods because its gonna be a sleeper for now.(except for rims so the brakes can fit)
engine:
stage2 7-bolt stroker kit
manley valves standard (full intake and exhaust)
recised lifters
topline rocker arms (16 rockers)
manley performance springs, titanium retainers
manley 6.5mm valve stem lock
ferrea valve stem seals
topline complete gasket kit
prothane motor mounts
Dejon Tool CIP-2gS 3" intake pipe
k&n filtercharger kit (air filter)
Forge motorsports BOV(recirculating)
electronic boost controler
Espelier 80mm SS Exhaust
RRE racedown pipe
ported evo 3 manifold
ported evo 3 o2 housing
walbro 255lph fuel pump w/ rewire kit
mitsubishi 20G turbo w/ internal wastegate
act 2600 clutch kit
oil line kit(turbo)
hks turbo timer type 1
b&m short shifter
kaaz front lsd
ecm tuning dsm link
high flow denso injectors 720cc
agp fmic intercooler kit
ACT flywheel
BC 272 cams
adjustable fuel pressure regulator
eprom ecu
symborski shift kit, under hood shifter cable bearings
maf translator, gm maf
o2 sensor
AEM high flow fuel rail
crower adjustable cam gears
Magnus intake manifold
AEM UEGO wideband guage kit
msd dis-2 ( 2 channel ignition)
gnk dsm 4g63 iridium spark plugs stage 2 colder
msd 8.5mm ignition wires
unorthodox 2g pully kit
arp dsm head studs
arp dsm main studs
arp dsm turbo bolts and washers
samco sport coolant house (looks good)
guages:
air/fuel wideband
glowshift boost/vacuum
glowshift oil pressure
glowshift oil temp
glowshift water temp
glowshift tranny temp
glowshift tachometer
handling and braking:
RM DSM sway bars
dc sports carbon steel strut bars
h&r racing springs
koni adjustable shocks
stillen big brake kit(front)
OEM EVO 8 brake kit (rear)
Electronic boost controllers are finiky and tempermental at times. With as much boost as you'll push with a 20g I'd just get a standard ball and spring boost controller. Its a lot less expensive also. I'd also stay away from the iridium spark plugs. Regular Ngk bpr7es plugs should work just fine.
Dsmlink can control whatever injectors you can throw at it. I would go ahead and get some 1000cc injectors and then you'll never have to upgrade again, should you decide to.
+1 on the transmission too
