2G Previous owner had O2/ECU wired wrong, is this normal
Iliketurbos94
Mar 10, 2018
DORR, Michigan
Hello, been here awhile but rarely post. Have a 97 gst. Silver/grey metal ecu. Not blackbox.
Previous owner did a hack job rewiring front o2 and knock sensor. I've since fixed it. But noticed he had the front o2 sensor plugged into what I believe was the cruise control harness?
The guy freaking spliced INTO the CC harness for the o2 signal and had it ran to the ecu!
Could this have caused any damage to the O2 sensor or ECU?
The car runs about the same. Hoping I rewired it correctly using the 2g ecu pinout. (95-96 same as 97?) I checked continuity on the oem harness wires and reconnected n electrical taped.
Could this cause an issue with radio interference of the o2 sensor? Signal seemes to be intermittent going between 0.020 and .900ish volts.
Pics were taken while cruising at 60. Graph log is about 15/20 seconds long.
Obd reader updates about every second so live data is not 100% sreamlined.
Does everything seem normal here??
I can get more pics if anyone's interested
Thanks for your time
