DSMDEMON93
- 319
- 2
- Feb 18, 2009
San Jose,
California
Hey guys, so my 95 GSX is running strong at 143,xxx miles, compression is about 165/165/170/170
I Want to keep it going as long as it can. I will be putting some power down real soon.
From what I know, Stock Rod bolts stretch over time, and could potentially result in a spun rod at some time, depending on conditions. I'm looking to buy some ARP rod bolts to keep the engine going.
THE OTHER ISSUE. When un-torquing the OEM rod bearings, I am afraid that re-seating them will cause premature bearing failure. So, might as well replace the bearings and plastigage them to check clearances.
Can all this work be done in car? I know its easier to pull the engine, but I heard the FSM has a section to replace bearings in-car. True or False?
I Want to keep it going as long as it can. I will be putting some power down real soon.From what I know, Stock Rod bolts stretch over time, and could potentially result in a spun rod at some time, depending on conditions. I'm looking to buy some ARP rod bolts to keep the engine going.
