JusMX141
Moderator
- 15,147
- 1,292
- Dec 13, 2005
Greensburg,
Pennsylvania
"Yes".Well dam Jus. What is the bad thing, the bearings, thrust plate, impellers???
Mainly the thrust system as the plate which is used on these units is actually a T2 thrust plate because the bearing housing is so small...meaning this would be the size-equivalent of using a standard TD04 thrust plate on a S300 or HX40 in terms of thrust load vs. wheel specs.
Apart from that it's just a journal bearing Chinese knockoff of a GTX3582R that you can buy on eBay all day everyday for $350ish.
When they first appeared on FP's website they had a disclaimer saying the turbo should be used at or below 20psi of boost pressure, but somewhere along the way that information was removed from the listing.
