Precision turbo 6031
05Nissan350z
155
Oct 23, 2013
Canton, Ohio
Hey everyone how is this turbo are they reliable it'll be on my daily? I'm wanting to upgrade from my small 16g. How is the precision in comparison to a mhi 20g in size? Any info on the 6031 would be great thank you!
Had the 6031 on my 1g when I got it. Seems to be pretty reliable. Wasn't tuned so I don't know the numbers but the butt dyno felt good. Now I am selling it to put my top mounted setup on.
Haha I knew you'd respond to this, Because I was looking at yours.. I just don't know much about turbos just want something bigger than I have now. Pretty sure I'm maxing it or pretty close,
Wish I could help you out more. I would have kept it on but I like my Shearer top mount. Now from my seller stand point. This is a must have!!. But seriously I am sure another member will chime in.
me too, i'll definitely be more interested with some more feedback on them!
The PTE DSM-flanged turbine housing (assuming that's what it has) is going to hold you back from making airflow that the compressor is capable of, and also help make the turbo a little less-reliable (turbine restriction accelerates thrust wear and also causes heatsoak which can take the spring tension out of turbine sealing rings in a matter of a few pulls).
If you stay below 25psi or so you should be OK...above that (especially on pump gas) you'll want a T3 turbine housing on it for sure.
Thanks for the reply. I'm only running 20psi right now. Or should I just stick with mitsu turbos? I just installed an evo 3 manifold don't really feel like taking it off already LOL. Switching to a T3 turbine housing will make me have to do so wont it?
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
