BB precision 6152 Turbo
Yes it can be done. It is basically a gt35r. Have people ran 10's on those? Absolutely. It has been done on both th sc and scm versions also without nitrous.
it depends on wether or not your talking about the scm or the sc6152. The scm turbos dont really like pump gas ( have a 6152 now) but ive heard the garrett housings are a bolt on for them so id buy the sc 6152 if anything.......and yes.......they're def. 10 second capable
What are you talking about???
I would love to hear this one explained...
the bolt on housing is better for pump gas...If your running race gas and high boost they tend to choke up top...
Yeah I agree with nikeebabee, my scm6152e goesn't have anything against pump, of course pump for me is 105 octane e85 :thumb:
a really big turbine wheel in such a small exaust housing doesnt permit enough flow so choke comes sooner.
Kind of having a brain fart right now but im sure ill think of the explanation as to why the bolt on housings suck on pump gas.....although i know it has a lot to do with the ar
Some would say that a bolt on housing sucks on pump gas compared to a t3. That is because with the bolt on housing you have a higher chance of knocking since the exhaust is more restrictive and heat builds up.
I can tell you from experience I NEVER had an issue with my scm below 27psi on pump gas...
Past that it would surge and really start to top off up top....
On pump gas how much boost will you really run... On race gas you'll be making more boost and flowing much more air hence why the scm would choke and the t3 would begin to shine...
By the way a local made 469fwhp on 22psi with a 2.3 on PUMP 93 octane...
I was just stating the reason that the other guy might be trying to explain. What I said has been proven on some turbos also. I wouldn't be one that could argue that since I have a bolt on 50 trim and run 28psi on pump or race gas. I don't have any knock issues with pump gas at that psi. On race gas I just add more timing and lean it out some with Dsmlink. If I had a built bottom end I would run even more on both pump and race gas.
