power windows just stoped working and door buzzer wont go away
sadc
274
Feb 17, 2008
Kapolei, Hawaii
So I was putting everything away because I just got done install my alarm. tucking everything etc. Just As I was about to leave my windows wouldnt roll up. Both of them, not just one. Funny thing is that my door locks still work on both sides. Just my windows dont work. Checked my fuse. And its still good. Just to be sure, I got another fuse and swapped it. Nope, still a no go. Went to go look at the relay under the driver side. I believe its this one
where the red wire goes into
http://www.dsmtuners.com/forums/att...y-wire-question-powerwindowbypassjumper2g.jpg
It looked ok but again I switched it out just in case. And nope still a no go. So what could it be? Oh yea and the door buzzer just stayes on? Dont think it has anything to do with it. But you know when you key is on the "on" position. And your door is open? Your door buzzer is suppose to go away? well mine dosnt anymore. Only when the key is out, then it turns off. WTH!!:banghead::banghead:
Oh yea this is for my 1997 gsx eclipse
it sounds to me like you've got something wrong with your instrument panel
So I stuck a voltmeter in the relay area, and im getting 12v's on the left side of this picture
My door buzzers are still going off even with my key in the ON position. and my door open. I forgot to mention when I was doing my alarm, metal touched my Ignition wire and there was metal open. It sparked. Idk if that has to do with anything.
The main switch (in left door) provides power to both windows via it's up/down switches. The switch in right door provides power to just right side. However the motor ground for both window motors also goes through the left switch.
Does the right side switch work? If no, do you have the window lock switch pressed (on the left door). This switch provides the ground for the right side motor (when it's up) when using the right side switch so if it's broken the right side switch won't run it's window. Of course if the ground wire is broken going to the left switch, neither window motor is going to work. This is the black wire in the 9 pin connector.
