delta448
DSM Wiseman
- 3,627
- 322
- Jan 13, 2006
Waynesburg,
Pennsylvania
I spent today installing my aftermarket stereo equipment. After I was done I had this problem. I know what I did wrong, -I didn't disconnect the battery before I disconnected / reconnected the power windows / door lock harnesses from the switches in the front doors. So now I have no power to either window or the locks from the driver's side, and only the power lock is working on the passenger side.
I found this mod on the VFAQ but I'm not sure if it will help. I checked the fuse box under the drivers dash, and there's no fuse labeled power windows or locks. I checked the fuse box under the hood and the fuse that was labeled power windows there was still good. Is it bad relay(s)? I would have tried to do the above linked mod if it were still daylight here. Anybody ever do this mod before or have this problem before?
Good help will be rewarded with rep points.
