420A Power window install?
Slick-_-Rick497
Nov 15, 2015
Gainesville, Georgia
i have a 99 rs that is like to put power windows in, I know a lot of universal kits come with power locks to but I don't really care about those. I'm just wondering how I hook them up to switch power after there installed?
Instructions should come with the kit, but if not then use a test light and poke around in the fuse box. Chances are you will find an unused fuse whose power is switched with the key, or at least a power wire that would work. Won't recommend piggybacking off another circuit though.
Don't get a universal kit. All you need is the power window 'stuff' out of a GS, GST or GSX along with the switches, door panel and door wiring harness. Under the dash you just has to plug in the relay and you are set. It's super simple. I believe 2gnt.com has a wiki write up.
  • For sale 4G63 Frontline Fabrication V2 Billet Valve Cover
    Frontline Fabrication V2 Billet Valve Cover $750 + shipping & paypal fees* swivel AN fittings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
