power window and locks dont work
slow2g420
Apr 12, 2009
De Pere, Wisconsin
i have a 95 tsi awd and for some reason i cant get the window on the drivers side to go down or the locks to work. i checked all the fuses and they are good. i also checked the wires with a test light and wasnt getting anything. bad wires maybe? im really at a loss for what to do and i cant find a wiring diagram anywhere. i can get the passenger side window to go down and up with the passenger side switch though. also my radio doesnt work and neither does my blowers for the ac and heater. all of this connected to a bad ground? any help would be awesome!
Have you pulled the door panels and checked the wires in them? I remember my fuses would keep blowing until I took them off and found that the window had been rolling down onto them and broke some so then I had to solder all of them back together. Could be the actual switch is bad. My passenger window still blows the fuse if you use it but if you roll it down on the driver's side it doesn't... and there aren't really that many wires on the passenger side so yeah... think it's my switch. So hope that helps or at least gives yo some idea of what could be causing your problem. :hellyeah:
Replaces all your fuses.
I tried that on my previous gst, and found that after replacing one fuse for the part that wasn't working (forgot what it was), one other thing stopped working, so i just replaced them all and BINGO, weird but hey, worth a shot.
yea ill re check the fuses. they seemes good tho. my passanger window wont roll up now. i just tries it and it doesnt work so there must be a bad relay or something like that
i just checked all fuses and they are good. i took out my radio and checked the plug from the car to the radio and it to has noe power. my power seat has no power either
Has anyone figured this out? Mine has the same exact problem. Windows, locks, radio, and seat not working...
Just figured it out... its the big 100amp fuse, mine was blown. Replaced and now everythin works:)
