Power Locks Not Working
epreski7
66
Aug 17, 2014
Oviedo, Florida
My power locks on my 98 gs spyder aren't working. When you press the switch on either the driver or passenger side nothing happens. Is there a fuse or something that went bad or is it just both the switches which I find unlikely.
I have this problem right now as well. I can hear the clicking in the drivers rear speaker area, think a solenoid in the doors is causing the issue, I checked all my fuses and they were good. When I hit the lock a bunch of times in a row I hear the relay going, but the locks don't move.
I'm in the progress of installing an alarm/remote start/ turbo timer combo and I need those wires anyways to tie into, guess I'll be figuring out the cure to my problem sooner then later!
I'll post back here with anything I find, if you do the same :)
I"m a picture wh0re too so I'll be posting a bunch as I go.
