2G power steering pressure switch
The PS pressure switch causes the ecu to bump the idle speed slightly when it recieves steering input.
Mine was unhooked for a while with me even knowing it. I don't see a problem, but you may want to kick your idle up alittle to make up for it if it drops too low when not rolling and turning.
Hmm thanks! But i had a brain fart today. Can i put the switch in the high pressuer side of the power stearing line? Sorta like the srt? And put a t fitting before it goes into the rack?
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
