polyurethane motor mounts
spawn87
908
3
Dec 6, 2007
sacramento, California
i wana buy polyurethane motor mounts because they be a less stiff than strait metal for my gs-t but every where i search i keep getting inserts only and i rather get the hole thing...any one know where i can find them or is it just as good to get the inserts and save my money?
can someone post pictures of all the actual mounts for the 2gen gsx? i have too many mounts for different models and different cars laying around and cant figure out what goes were? please help. a P.M. would be fine.
Just fill them w/ Window Weld, works great and is like $12...big_d
Absolutely! I've done this. Why waste the money? You have to spend the same time pullling them out regardless. I use PL polyurethane constuction adhesive. The base formula liquid nails does just as good, but mor expensive. . . But were talking dollars more vs. how much poly inserts cost. . . I don't understand why they sell.
If this helps anyone that might want to replace the stock mount I found someone else bought aluminnum mounts with polyurethane in another forum and for a 2G
http://www.dsmtuners.com/forums/newbie-forum/415561-how-replace-motor-mounts-2g.html
and some guys are. Talking about buying a polyurethane cutting board and cutting pieces then pressing the pieces into gaps in the. Mount and then making it all firm with window weld I just took out my front mount today and the rubber was so broken I belive. Repairing it will be worse then replacing them especially since the urethane. I bought today was about 30 dollars small. Tube from oreillys 3M and I'm finding inserts for not to much more so if yur mount is really damaged like nothing left. I recommend just buy new inserts. If small crack quick fix I mentioned and the other guys also good. I'm going to return window weld tomoro and look for inserts. Now
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
