pnp and alum radiator help
jw wrenn
68
Jun 11, 2013
Oxford, North Carolina
Ok guys I have 2 quick questions how do I go about setting up a 4g63 aluminum radiator in my 2gnt like will the rad its self fit the mounts? And where can I find a plug and play ecu for the 420a any help on either question is appreciated
Thanks guys I knew I had to make up hoses I was gonnna use unmolded hose the longer hoses shouldn't be That badi figured there wasn't a plug and play afteer weeks of searching I wonder if I could do every wire with a male and female connector kinda make it plug and play
Yea you could buy a couple male and female weather connectors. Mouser has a ton to choose from in a variety of styles and number of pins
Why not get the proper molded hoses so they fit right? Using unmolded ones may cause cavitation in the coolant if there are kinks in the hoses due to the bends if they're that extreme. I'd get the proper molded ones to be safe.
^exactly I may be able 2 hoses and put a pipe in between
Exactly to snowborder714
You might want to look into the stainless steel flex hose they have for radiators. They come in different lengths and ids. I had a rubber flex hose on my camaro that I left on for about a week due to the fact that it kinked like a mofo.
What I was gonna do was go up to oreillys and pull a few hoses and cut ### I need and use a metal pipe and clamps to join up the hose I'm looking at a lot of cars hoses now fining bends I could maybe use Ive noticed that neons hoses have the angles I need trial and error seems to be the radiatior solution
The ### is meant to be what
You know there's not much gain if any with an aftermarket radiator on a stock motor right? Waste of money really, as nice as the radiator will look with ugly routing of the hoses defeat the purpose. I still think it's cleaner and better to find a welding shop to tig in the openings in the right spot then use proper hoses. Just my thoughts though never seen anyone do it before.
I've heard many times they stop making these rads for us? I know it's on the website but every has said they stopped.
We looked into buying 2g N/T aluminum rads about a year ago. We couldn't find a single one. Every single supplier who claimed to carry them, couldn't produce a single real-life rad. A picture on a website? Sure, we found lots or those. Like I said, that was about a year ago and things may have changed since.
