LarryJoe
- 376
- 15
- Feb 10, 2012
Davisville,
West Virginia
I use the cheap cxracing aluminum radiator. Mounts up like stock, stock fans fit perfect, and cools perfectly.
Sorry then i seen it on some different maybe its just there set up a little different. and im not trying to argue just trying to learn but every pic in this thread i dont really see a problem desides having to run a external trans cooler, idk tho http://www.dsmtuners.com/forums/app.../140333-who-has-nicest-420a-engine-bay-5.htmlmaybe you forgot the engine orientation that puts the 420a turbo right under the hose instead of beside the turbo like the 4g. Your post was unnecessary and just bad info. 4g rad isn't good for a 420a.
Yeah but the 420a rad inlet is already on the passanger side so how does that make sence that it wont work, so if they are using a stock rad by your theory it wont work! to where as the 4g rad inlet is in the middle, im not saying that it will work any longer because..... im not going to get into this any longer then i have to. i didnt know about the outlet being on the driveside so i see your point there but thats nothing that alonger rad hose cant solve.The problem is exactly what I told you. 4g turbo sits towards the driver side, the rad inlet towards the pass side. A 420a with a turbo will have the turbo towards the pass side and using a turbo rad with the inlet towards the pass side would put the inlet right over the turbo. .
thank you, this is exactly what I was saying. there is a big difference in turbo locations.
maybe by your past post you seem to be forgetting something and also giving out bad info.maybe you forgot the engine orientation that puts the 420a turbo right under the hose instead of beside the turbo like the 4g. Your post was unnecessary and just bad info. 4g rad isn't good for a 420a.
so in theory MJcanda is wrong your rad inlet is on the passenger side (fact) the 4g rad inlet is in the middle (fact)maybe you forgot the engine orientation that puts the 420a turbo right under the hose instead of beside the turbo like the 4g. Your post was unnecessary and just bad info. 4g rad isn't good for a 420a.
This is the only person who some what sees my point its not like im telling anyone to reinvent the freaking wheel around here you have something that no one makes a product for, so if you get the one for a 4g and have to customize the rad hoses and add a external trans cooler which would be better for your damn car anyways then whats the big deal.My understanding is the mounting pins are different. There's lots of solutions: use a turbo rad with custom hoses, use a Neon rad and fab up mounts or re-locate the pins, etc, etc. .
Lol isn't that both of your agreements against me
away from your turbo mounting point.
Lol whatever man I see your point your trying to say that what I said won't work when in fact it will so your missing my point and by saying I'm giving out bad info when I'm not just because your to lazy to do the work, w/e tho o/p do what you want buy the rad of this dude or get a little creative if your not scared to do the work
if you want to put cars up to make yourself feel better about yourself then thats your problem i could care less about this now have a wonderful day.
