Please help me identify this board on Turbo ECU
Louis
Mar 23, 2004
Seattle, Washington
I borrowed this image from another post. My question is what is the function of the board which takes up nearly the entire upper center of the picture? Unfortunately, I broke mine :thumbdown Thanks in advance.
Unfortunately, I don't know if you're going to find anyone that'll know specifics of the ECU that well anymore, now that TMO is out of the game.
You might try looking at a pinout of the ECU and trace the circuit pathways to the pins.
All I know about that board is it has a sticky black pad on the other side for some reason. :D
Psychlow: Thanks for responding. I guess I am mainly interested if the non turbo ecus had the same board. I can pick up a NT ecu much cheaper.
The numbers on the back of my board read "E538" if that helps.
Also, the board is in the IC110 position.
I'll vote... knock sensor input conditioner.
Tom
One of the things the vertical board IC110 takes care of is turning the power on to the fuel pump. I haven't traced all the rest, but I assume it takes care of several simple switching functions.
Steve
