psi4power
- 50
- 0
- Dec 22, 2002
so if you eliminate the o2 sensor, i take it you use the one down after the cat to tune with??? i know theres no cat on most aftermarket turbo backs, but u know with the placement after the cat
Uhh.... kinda. It's not really an A/F mix anymore.... some of the 'leftovers' get converted into other things in the cat, and like the other guy said, heat is another factor.the air/fuel ratio changes from the time the gasses pass by the o2 sensor in the o2 housing to the time the same gasses pass by the sensor in the cat?
