lucid15
- 527
- 0
- Oct 10, 2008
Portland,
Oregon
I just found out my water pump is leaking, the car has 89,9xx miles on it. My stock clutch is also beginning to slip. My goals are a 400whp Daily Driver / Street Machine with an emphasis on driveability while maintaning power. I am trying to make sure i covered all parts that should be replaced when doing these two jobs while also upggrading parts that are relevant to the labor involved for both the Clutch and 90k service.
Here is my cart so far:
- Extreme PSI Timing Belt Kit: Mitsubishi Eclipse 90-99
Timing Belt: Gates Timing Belt Only
Tensioner: 95-99 MD308086
Tensioner Pulley: 95-99 MD182537
Idler Pulley: 90-99 MD156604
Balancer Pulley: Not Selected
Balance Shaft Belt: Not Selected
Balance Shaft Eliminator Kit: Selected
-ACT Xtreme Street Clutch Kit : Mitsubishi Eclipse 90-99 Turbo
-ACT StreetLite Flywheel : Mitsubishi Eclipse Turbo 90-99
-Extreme PSI Complete Clutch Line (Slave to Master Cyl.): Mitsubishi Eclipse 95-99
-OEM Clutch Pivot Ball : Mitsubishi Eclipse 90-99
-OEM Clutch Master Cylinder Assembly : Mitsubishi Eclipse 95-99
-ARP Pro-Series Flywheel Bolt Kit (7-pieces):Mitsubishi Eclipse 92-99 7-Bolt
-OEM Throwout Bearing : Mitsubishi Eclipse 90-99
-OEM Clutch Slave Cylinder Assembly : Mitsubishi Eclipse 95-99
-OEM Water Pump Assembly : Mitsubishi Eclipse 90-99
What am i missing?
What am i missing?
