P0120 code-throttle position sensor circuit?
well I got a code from the tps so I cleared the code and ran pids/data stream at work and I recieved perfect voltage from the tps. So i guess clear the code if you havent already and run a data stream/pid to see what kinda voltage its running. If you have you have a faulty component...please give the definition of that code as my chiltons is in my tool box at work.
Andrew
The code pertains to the entire TPS circuit, which includes the sensor itself. I've read that people have changed the sensor and checked the wires and everything, and the code will still return. This is on a totally stock car too, no mods. From what I've seen and read, this is a common problem on both the 1G and 2G.
Yea well I've ALWAYS had that ####ing code, I've replaced the TPS and other stuff and it does not leave.
It's fun when they wont let you do a smog check because of a single engine code.
Circumstances force me to figure it out this week I guess, so If I learn anything at Road Race I'll let you guys know.
