2G Overheating
Velmin hu
69
May 25, 2019
Las vegas, Nevada
Greetings my car gst 96 seems to overheat go up in temp not to red but little higher whenever I drive it and then come to stop idle for couple mins it starts to climbing and feel like it drops 100 rpm when is Ideling .
also my a/f gauge seems to show ———-.
Here is a video
So the fans do kick in when it reach certain temp above normal, is it due to me pushing it psi kinda hard I’m getting 20 psi on big 16g evo I do have all supporting mods except stock intercooler? I check for leaks thanks
Stock radiator fans will kick on right around 200 degrees. I believe the magic number is 213 but dont quote me. Now according to my logs, anywhere between about 194-206 the needle on the temp gauge is right in the center. So, due to you soring past the middle line, you should be able to see if your fans are kicking on. If they are not then you have narrowed down your problem.
Keep in mind, keep your AC off. One of the fans will kick on low speed when your AC is turned on.
U guys are right, check to see if the radiator fan is coming on.
I'm betting the thermostat is shot, stop by the parts store for a new one, its probably under ten dollars.
I'd check for leaks too, but that's just me being thorough.
Yes the fans kick in the temperature drops to normal in the center but I am wondering how come it went up rised. Never have my cars done it before thank you.
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
