1G Overheating?
AndrewC
5+ Year Contributor
54
Nov 6, 2017
Portland, Oregon
Got a couple things to ask. One is my oil pressure gauge isn't working. The dummy light works because I used it to prime my engine on oil. I see only one sensor on the oil filter housing that has a connector on it. Next is I'm trying to bleed my coolant, I'm using a no spill funnel and when I'm running the car it immediately starts heading to H. But I see the coolant and it's not over heating. I see 3 sensors on the neck. The AC one, the one with 2 prongs and they seem to be falling off, and a single prong. They're plugged in besides the AC one. Anyone have anything on the overheating gauge? I'm thinking that maybe the thermostat is stuck but not sure.
1g or 2g? The car uses two different sensors for the coolant. There is one sensor for the ECU and one for the gauge. The one for the gauge could be bad. Now when the car over heats does it get hot enough to turn the CEL light on? If you think your thermostat is stuck closed then I would just replace it. Its cheap and good thing to try if you believe you have no air in the coolant system.
It's a 1G, but the thing is it's not over heating. The car was pegged at H and the water and hoses weren't even warm to the touch. It just started climbing fast as soon as it started. And I'll check for the other sensor tomorrow, I know I have one of the sensors which is probably the dummy light which is pointed to the front. And on the back you mean like towards the passenger wheel or towards the firewall?
page-9
I actually see the sensor you're talking about on this picture. I don't have or at least don't see the wire that goes to it so I probably don't have the plug for it either.
It should be there now, but I see the oil pressure sensor and the weird connector it has but I don't have the plug on my harness.
It goes the same route as the oil dummy light. Somebody probably just cut it off somewhere along the harness. Just go looking for it and I'm sure you'll find it. Add some wire and connect it back to the sending unit.
I'm still having problems with over heating. I know the radiator isn't clogged and I remove the thermostat there's no leaks. But it says it's overheating still after not even 5 minutes of running. Still doesn't look like it's boiling but the car now dies idling and now won't crank.
Why haven’t you replaced or tested the CTS (coolant temp. Sensor) and/or replaced the sensor for the dash cluster temp. display if the car is still overheating?
When you say immediately goes to hot on the gauge, do you mean as soon as you start it? Or just after a few moments it gets hot before it should regularly?
If there isnt enough coolant or any for that matter, the block can get hot withouth there being enough coolant to go through the hoses to heat them up.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
