EagleTalonTim
- 830
- 13
- Jan 10, 2007
Brighton,
Tennessee
As the title says, I have been having a strange overheating problem for the past 2 months or so. After a 45 min to 1 hour calm drive, the center of my manifold is glowing red hot and my coolant temp reaches 220 to 230 degrees. The strange thing is that I am not losing coolant or oil, there is no coolant in the oil, and no oil in the coolant. I just went for a test drive around the block (4 miles) and within 2 minutes of hard driving, the coolant temp already hit 230. When I got back, the coolant lines were hot and pressurized.
So far, I have checked :
Water Pump : Replaced 1 month ago thinking this was the problem
Radiator : Replaced 4 months ago (stock).
Thermostat : Tried 3 different ones (160, 180, 192) Fail Safe
Radiator Cap : Replaced with water pump, 16psi
Cooling Fans : 2 slim fans constantly running when key is on. Both work.
Radiator Hoses : All brand new and clean.
Coolant Mixture : 40:60
Turbo Shaft Play (Evo 3 16g) : very little side to side play, about 1/16" to 1/8" in/out play.
Intake Pipes : All spotless. No oil or coolant.
Exhaust : Not Clogged.
Compression (Warm Engine) : #1 - 140psi, #2 - 135psi, #3 - 140psi, #4 - 145psi
FMIC : Clean all the way through. I have had this installed for over a year.
I do not have a wideband O2, but I use my datalogger for checking fuel. During normal driving, my O2 reading goes from .05v to .75v constantly. When I go WOT, it hits .84v.
This problem started happening after the car sat for 3 to 4 months while I waited for parts to rebuild the bottom end. I replaced the timing belt and pulleys, did the BS removal, replaced the oil pump, and replaced all rod and main bearings with ACL bearings. The car does smoke a little at WOT, but it is black smoke. I had been working on the fuel system awhile back, but got tied up in other things that needed to be fixed.
Any help would be greatly appreciated! I really need it on this problem!
