over heating help me
92tsi2008
Apr 15, 2008
LITTLETON, Colorado
Please help! I just bought the car with a brand new motor and all new parts. It ran fine for awhile then it blew a heater hose so i replace the hoses. i thought that was why it over heated but the next day it did it again and will not quit. when i park it pisses steam out of the overflow bottle. i have replace cap, tstat and rad. please help im lost:cry:
i took the tstat completly out and it still did it. i aslo did the exhaust gas tester in the coolant:notgood:
I would say head gasket if you kept driving after it overheated.Also your head could be warped now.good luck man.
Once you get it all figured out be sure to put Water Wetter into the coolant system when you have it fixed. It helps keep the heat down real well.
are the fans working properly? also if i am thinking correctly when you take the t-stat out completely the car would over heat because the coolant doesn't have anytime to be cooled down in the radiator, it just keep going through. also i don't know what temp t-stat you are using but the stocker is a 195deg. you might want to change to a 180deg. not that this will solve the problem but it does keep temps down a little.
I would start by feeling your radiator hoses to see if maybe your radiator is pluggged.
After that I would pull your cap off, start the car and see if its bubbling.
After that id check compression
Jared
Please stop posting, this is a dead thread.
Org start date=04-30-2008
Pev last thead before today= 05-04-2008
I feel the OP has in some way delt with this issue!
