Only two injectors getting power????
That is what the resistor box is for ^
Did'nt realy read the thread, but Did you test the power transitor
most of the dsm's I've seen not firing on 2 cyclinders that was the problem
Dont Forget The Turbo And Non Turbo Ecu's Are Not The Same. Even If The Ecu Worked Great In Your Buddies N/t It May Not Drive Your Turbo Injectors. Different Resistance Between The Turbo And Non-turbo Injectors. I Had Same Problem A Few Years Ago And A New Ecu Did Me Fine.
I was told that I could start it up and rev it but it wasn't a good idea to drive and boost with it since the fuel trims are different I'll find that thread.
Isn't that to do with spark....I know I'm getting spark..Also i tried two different ones
I tried this and I got nothing. Does any one know how to test the wires
Ok so it's not late and I read the thread now...:p
Did you check for continuity? or test the Ohms ? of the wires,you should be doing the first
You sould be pulling the ecu and testing the pins of the wiring harness to the injector clips for continuity... to rule out a break in the wiring
Have you opened the case of YOUR ecu to look for damage?
Also why are you trying to start the car with a N/T ecu?
the ground that is in about the middle of the firewall. Has about 3 or 4 wires. That whole piece of that loom is melted together. If I can get this other talon in town for cheap enough I will just scape the car I think, unless I can get a new wiring harness for a good deal
