2G One bad rod bearing but rest were fine
ScarFaceBoy
Mar 29, 2023
Woodbridge, Virginia
So I have a 97 eclipse gst and one and only one of my rod bearings desided it wanted to go and if messed up my crank but can’t find one anywhere and the old bearings that were still good was loose when on the rod but was tight on the crankshaft and I’m not sure what to do I know I need to replace the crank
The engine needs to be torn down inspected and cleaned. If you can't find another crankshaft you may have to have that one turned down by a machine shop and run undersize bearings. The connecting rod that had the bad bearing should be checked for out of round and may need to be reconditioned and I would replace the rod bolts as well.
    • george bromwell
    • pma1123
    • Sdcryan1
