?? on built shortblock
GrnZ
102
Feb 13, 2007
Chicago, Illinois
Looking to buy this shortblock from a local he says its a 2.4 stroker , it has a 7bolt eagle crank ,eagle rods,weisco pistons , im not really sure if its a 4g64 or 4g63 block. Can someone help me by looking at the pics that i have ? Also will i be able to use a 6bolt head ?
Eagle crank and rods are clearly marked. The block has an idenfication plate on the back as well that should clearly indicate whether it is a 4G63 or 64.
Can't help you on whether or not you're getting a stroker or not.
I assume you've already got a 6 bolt head?
get me a pic of the timing belt side, I can't promise I will be able to tell, but it will give me a better idea.
IIRC I think the 2.4 had individual main caps. This may be the 6 bolt I am thinking of......
Yes i have a nice 6bolt head already. I really just need to know if it will work on this shortblock or not .
The part number on the crank you need to see is right beside the eagle logo... You can look the crank up and see if it's a 100mm crank or not.
You can use the crank in either a 4g63 or 4g64. The stroke is the same either way.
And yes, you can use a 6-bolt head. I'm sure you know exactly what you need to make everything work.
So from the pics would you say this is a 4g63 block or 4g64 ?
It is a 4g63 7 bolt block. I forget which years came with the cradle.
Im sure all 7 bolt 4g63/64s came with girdles. If it is a 4g64 it should be stamped on the side of the block close to the water pump outlet. That said i agree with nuclearr, thats a 4g63 block. 4g64s have more oil drain holes drilled into the block
Heres a pic from my build awhile ago. this is from a 7 bolt 4g64 out of a 1999 eclipse spyder gs. Its stamped by the oil filter housing/water pump outlet.
Thanks ! I got the numbers and looked it up , 2039375900B7 = Eagle 100mm crank :D
