silvreclips
- 1,279
- 348
- Jul 19, 2005
Greenville,
South Carolina
Little background info. Rebuilt motor back in Spring 08. Has approx 30k on it. Put a topline oil pump on it. After 1.5 yrs it started acting up in a similar way as this one. Idle pressure was really low when warmed up and pressure would fall off randomly when driving but would build back up if you reved it. Replaced it with a milling oil pump and after 1 year its doing the same thing only worse. Idle oil pressure is very low when warm.
This is getting rediculous having to replace the oil pump every year something has to be causing it to have low pressure. I dont think its a gauge problem since the pressure builds up fine when reving the motor its just at idle. I do have a sandwhich adapter on the oil filter with an external oil cooler attached. Never had an issues with that setup on the stock motor before it blew.
Planing on changing it with an oem pump but really would like to try and figure out why 2 oil pump have failed so quickly.
Heres a quick vid of the issue.
http://s189.photobucket.com/albums/z173/SilvrEclipse/VID00001-20100824-1327.mp4
