420A Oil pressure sensor
Eclipseturbo4
73
Jan 12, 2007
Cedar Rapids, Iowa
Where in the world is the oil pressure sensor.. I don't have a gauge its just for the idiot light but the problem is I've found 2 sensors on the back side of the motor I'm sure ones the oil pressure sender I wanna tap a gauge in there and get a reading and not just a light... is it the sensor on the drivers side?? If it is how the hell do I get to it to get it out??
Sent from my SPH-M910 using Tapatalk
Yes its the sensor all the way to the transmission side facing the firewall. 27mm deepwell from underneath or pull the intake tube and battery out whichever you prefer.
There's a special tool (it usually costs around $10) for removing oil pressure senders that's deep enough to accommodate them. The one you want is 1-1/16" (or 27mm, but they're rarely labeled in metric units). But if you can find a 27mm deep socket, by all means, use that.
Ok how do I get the sensor unplugged?? Its completly blind up there idk how that thing even unpluggs
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
