1G Fuel Pressure Sensor
Tandiey
Aug 8, 2004
Melbourne, Florida
Ok guys, I don't do much posting here, normally alot of research which prevents the need for me to post. I usually find an answer to every problem I'm having on this site.
However, I'm in a bit of a dilemma as to what exactly a Fuel Pressure Sensor is. Supposedly I need one for my 92 GSX and I don't know what to look for at the junk yard.
If someone could please maybe take a picture of the engine bay and circle the part it is, that would be the absolute most helpful thing. I've asked a bunch of my dsm friends and no one has been able to tell me what part it is. Thanks a lot guys! :confused:
I think you might be referring to a fuel pressure solenoid, dsm's don't have a sensor for fuel pressure. If that is what you are looking for it's not neccesary to have one. You can eliminate it, using one of the many writeups on emissions equipment removal.
The fuel fressure control valve is located on the driver's side firewall inbetween the brake master cylinder and a small fusebox above the brake booster. It is the middle of the 3 black solenoids, there should be a vacuum line going from it to the fuel pressure regulator and a line going to the intake mianfiold
Auto RS T said:
The fuel fressure control valve is located on the driver's side firewall in between the brake master cylinder and a small fusebox above the brake booster.
Otherwise known as the fuel pressure solenoid.
Steve
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
