Proper fuel pressure
ChrisB84
Mar 23, 2012
Spokane, Washington
What is the proper fuel pressure on a 1st gen turbo in a 2nd gen talon awd. Also what are the specs for the fuel injectors, where should they be at??
2g- 43psi - 450cc
1g manual - 37psi - 450cc
1g auto - 43psi - 390cc
So, if you're asking what fuel pressure for a 14b (stock 1g manual turbo) on a 2g 7 bolt motor (that has 450cc injectors stock). The answer would be 43psi base fuel pressure.
Not really sure what you mean by where should your injectors be at... please elaborate.
I agree with both posts above. The OP, if you want to know where the injectors should be at you should get them cleaned and flow tested. Your injectors should flow within a few cc's of each other. If your injectors were never cleaned I highly doubt they all flow the same.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
