2G Oil pressure sensor housing cracked
Dbl_spirit
22
Sep 28, 2023
Plummer, Idaho
The area in which the oil pressure sensor goes is cracked. Is there a replacement part or is that the oil pump? I'm not an expert. TIA
You could have it TIG welded since it is aluminum but a replacement, as @chrisman287 said, is a sure fire way to solve it. Just don't over tighten the sensor, that is what cracks it to start with.
Trying to do the oil filter housing. Stuck on the timing cover bolt. Any ideas? Thanks
The one behind the cover? You’ll have to remove the bolts that you can see from the cover then pry back enough to get a wrench in there. Take note of which bolts go where as there are varying lengths. You can use a piece of cardboard to make a little diagram.
It’ll help a lot if you have a second set of hands to hold the cover back. That’s how a buddy and myself did his.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
