Broken oil pressure sensor plug
Brad97SilverGS
Sep 21, 2010
Victorville, California
Hello my names Bradley im out in california and a N00B to DSM , i just bought a 97 eclipse GS non turbo and i am replacing the oil pressure sensor as it seems to be leaking, but in the process of removing the green plug / connector I BROKE IT due to old age
(yes i know u have to push in the red tab and then lift the green portion of it but it still broke)
it will still plug into the new oil pressure switch but it looks like ill have to zip tie and or electrical tape it to make sure it doesn't shake loose as the green clip is the portion that snapped off.
i am trying to get the leak fixed for now, will this suffice for now?
or should i take an alternate route and fix it another way?
Does anyone know where i can buy a new one? because i CANNOT find one ANYWHERE on the internet
didn't see any other answers to my question on the forums
thanks guys! :hellyeah::rocks:
do you have a pic i think i know what you talking about but not sure is this where theres a screw and the connector slides over the screw?
  • Wanted 6 bolt NT water pipe
    • chrisman287
