Oil Pressure Sensor?
blade970
190
Apr 4, 2009
Billings, Montana
Ok, So..I have This wire....
Hanging from the front of the car. From what I have read it is the oil pressure sensor wire.....that connects to this...
Correct?
Ok, so then what is this...
(the little sensor on the left)
and what do I plug into it?
That is correct. The wire in the top pic goes to the round sensor in the second pic which operates the oil pressure gauge. The sensor in the bottom pic is for the oil pressure light. The wire that goes to it should be in the same wire cluster as the other wire.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
