2G Oil pressure sensor
Mexjzl
Apr 15, 2022
Santa Fe, New Mexico
Does anyone know if I remove my after market sensor AEM Will will it drain my motor oil and what do I do to clean it I'm not getting good oil pressure readings some on told to remove and replace i LOL
Unscrew it from the oil filter housing. Get some Brake Parts cleaner and spray into the tiny hole that is in the end that screws into the OFH. Try to get any old gunk out of it. It doesn't look new, is it used? A new sensor may be in order. It will not loose any oil when you unscrew it (maybe a few drops), but don't run the motor with it out of course.
Hanging sensors off of the housing is something I don't do. I remotely mount them so there is no chance of it vibrating loose or worse yet, breaking off. We have had that happen. I run a -4an line to my sensor. Just letting you know about things that have happened, not that they will.
How can I order the right replacement part like what size just to make sure I ll get the right one
Is it 1/8 NPT male thread? Thank for the help, will wd40 work to clean the inside too?
That looks like a 3/8
Order from extreme psi and their kit comes with everything needed
The OFH has BSPT threads in it. Once you put a SAE thread in it, it is goofed up for life. FInd a BSPT to AN or SAE adaptor and save those threads in the OFH.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
