2G Oil pressure low after overhaul
joshuah
54
Feb 18, 2023
Saint Louis, Missouri
You know im 1st 3rd year with my 95 talon 4g63 and first 2 years i drove all over Saint Louis and my oil pressure gauge never functioned always has been at bottom. This last year I decided to overhaul tge entire engine and now with new rotating assembly and bs delete and new oil pressure sensor i dont have good oil pressure and im not sure where to look for whats causing the issue.
If you did the BS delete did you also rotate the bearings in the front to block off the oil passage? If not, that's a problem and many forget to do that part
