Oil pressure gauge
M4Dboost
94
Dec 4, 2010
springfield, Vermont
Just curious if this will work? branching the stock oil pressure and my secondary pillar mounted one off the same fitting. Havent seen anything about it so I figure here would be a great place for feedback.
Yea it will work just fine. Untill it breaks off and drains all of your oil in a few seconds, now that would suck. Like I said it will work, but I personaly wouldn't do it. I ended up with a NT oil filter housing that has 3 ports. I need one for turbo oil line, one for my aftermarket guage, and one for the stock dummy light, I didn't want a tee.
When I was trying to figure out how to install mine I read a lot of stories of the brass T-adapters and extenders breaking over time from the vibration. I saw enough stories that I knew I wasn't going to risk my expensive engine on it. I ended up just leaving the OEM sensors out (the pressure and dummy light) and replacing them with aftermarket ones (oil pressure and oil temp) directly. I don't ever miss the OEM oil pressure gauge though I wish its dead space could be replaced by something more useful now :)
